Recently I decided I might like to have a HKK Smoker chain on my OM Flyer. The brassy/black look of links matches my OM's scheme. So, I opened a smoker up and... doh! too short. Hm. So, I opened another one and got the chain breaker out, lopped off several links and reattached to the other smoker. Ample length was achieved.
But... there were big problems, it just didn't flow properly. I tried all manner of adjustments. As many of you will know, Smokers have that little screw and nut system instead of the typical master link. I tried adding a generic master link instead, in case I was doing something wrong with the oem method but that didn't really help. Anyway... what could go wrong? Over tighten that screw system on the smoker? I don't know. It seemed ok, the links didn't drag or seem stiff.
In the end... I put an izumi back on, smooth as butter.
Has anyone had a good experience with a smoker chain? Maybe it would be fine for a 20 inch and the problem was that I added the links so I could run it on the 26".
Is it just wrong to add links to a chain? I've done it before to other brands of chain without trouble (just don't push the pins all the way out with the breaker - because that's a bit more trouble).
Sign In
Register
MultiQuote
